How to install home security cameras on bricks?
stouty
what is the best way to instal the cameras on the eufy security 2c to bricks outside
Re: home security
Hello @stouty
Welcome to the Bunnings Workshop community. Thank you so much for joining us and sharing your question about mounting your security camera on a brick wall.
According to the Eufy manual, it recommends a 1/4 inch fitting which is around 6mm  I suggest using STAHL Masonry Kit 6mm Drill With 35mm Red Wall Plugs. This is a complete kit and includes the masonry bit, plugs, and screws to finish the job. However, if you feel that you need the next size up, you can use the STAHL Masonry Kit 7mm Drill With 50mm Green Wall Plugs. You can put a seal on the outside mounting cup using Selleys 75g Translucent Roof & Gutter Waterproof Silicone Sealant. This will prevent water from entering the mounting piece.
