Hello
I have a 100x100mm steel post that’s already concreted into the ground and dynabolted at the top into a brick wall. I need to install a steel gate to this post next. Grateful advice regarding the type of bolts or screws I should use when installing the hinge, noting accessing the inside of the post or gate frame is not possible. Thank you in anticipation.
