Hi team,
I'm about to lay Tuscan Path Porcelain Pavers 600x400 and have a question around the sub-base.
We are on dry sand (coastal WA) and limestone. Very coarse and dry. We will be laying pavers on a bed of mortar.
I have viewed the Tuscan Path installation video where they lay the pavers on a bed of mortar, and the ground is roughly leveled. There is no road base or anything going in here. Just level the ground and apply mortar.
Also following @Adam_W 's path paving tutorial, it looks like there was no road base here either. (This tutorial uses paving sand rather than mortar since it's using standard pavers).
A lot of traditional paving seems to require massive amounts of road base under the paving sand.
I'm hoping that the dryness/coarseness of the sand here, and the large surface area of the pavers, means I won't have to dig up tons of sand and replace it with road base. (FYI, I have compacted along the area before; it does almost nothing. Zero sponge factor... the sand just sits).
Also, this path is 1m wide, wedged between the house slab and a limestone block council retainer.
I'm just chasing your thoughts around how to best prepare the site for these pavers.
Cheers!
Matt
