We are planning to lay crazy paving on top of our existing concrete slab. I've read about a couple of different methods including using sand as a base or using mortar. We also want to raise the height up by almost 10cm.Taking into consideration the paver thickness, can we layer mortar directly onto the concrete slab to our desired height or should we be doing something different to increase the height and then adding a 10-15mm later of mortar before the pavers? Any suggestions or tips much appreciated.
