How to level cracked outdoor slabs?
Jacqueline23
Growing in Experience
I am wanting to level two separate outdoor slabs. Both have some cracks and have been painted or stained in the past. I plan to paint and stencil them when they have been levelled. What are the best crack fillers, primers and levellers to use? Thank you
Re: self level outdoor slab
Let me know how you go with that paint test @Jacqueline23. It will make your life a lot easier if you can prime the painted surface instead of removing it.
Soooo…. the rag had slight colour but when I tested it on another piece with known water based paint I didn’t get any colour removal. Maybe I might just have to hope it’s water based.?.?.?
Hi @Jacqueline23
I'm sorry, but would it be possible for you to redo the test? You might have hit a soft spot where the paint was loose. If you find another spot where the paint does not come off odds are it is solvent based. If you have a grinding tool, I suggest having a look at using Josco 75mm Twistknot Cup Brush. This is designed to strip rust and paint. Please let us know what the results are and we'll continue from there.
Jacqueline23
Hi Eric and Mitchell
Thanks again for being so helpful. Tried some other spots and it’s come off. My life should be a little easier now :smile:
Hi @Jacqueline23
That's good to hear. Please remember to put a slope on the slab when you re-level the surface so that any rainwater will flow away from the house.
Please remember to wear personal protection such as gloves, goggles and a mask when working on your project.
