I am planning on undertaking annual deck maintenance.
This is the first time I am doing the deck maintenance myself.
Looking for guidance on what is required (sanding, washing, etc).
The deck was installed brand new in March 2023 and this is the first maintenance since.Laundry Deck 1Main deck 1Main deck 2Main deck 3Main deck 4Main deck 5Laundry deck 2Laundry deck 3Laundry 4
Not sure about what oil was used originally on the deck.
Hello @MSD
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your questions about deck maintenance.
Undertaking your first deck maintenance is an excellent way to keep it looking great and well-protected. Since your deck is relatively new, you can approach the maintenance with less-intensive preparation. Start by giving it a thorough clean with a deck cleaning product like Cabot's Deck Clean. This will help remove dirt, grime, and any mould or mildew that may have developed. Use a stiff-bristled broom or brush to scrub the deck cleaner into the timber, then rinse it off with a pressure washer or hose, ensuring you don't use excessive pressure that might damage the wood.
Once the deck is clean and dry, inspect it for any rough or splintered areas. While a newly installed deck likely won’t need heavy sanding, a light sand with a fine-grit sanding sponge or paper, particularly on handrails or high-traffic spots, can ensure a smooth finish. After sanding, vacuum or sweep away dust to keep the surface clean for oiling or staining. There is no need to sand the entire deck, your goal is to smooth out any rough parts that might have splintered during the clean.
Finally, apply a decking oil or stain to nourish and protect the timber. I suggest having a look at this guide - How to oil your deck. Products like Cabot’s Aquadeck or Intergrain UltraDeck are popular choices, as they provide excellent protection while enhancing the natural beauty of the wood. Use a quality applicator, such as a deck brush or applicator pad, for an even finish. Follow the product instructions regarding drying times and apply a second coat if recommended.
Hi Eric,
I have finally gotten around to the deck maintenance. I did lightly sand the deck with a 120 grit. Then i did run my hand over the deck to ensure it the surface is smooth. Then I washed it down with a high pressure hose. Do I need to wash the deck with the Cabot Deck clean or can i start to oil the deck straight away once it dries completely?
Hi @MSD,
Great work up to this point.
If the deck is clean and no dirt or sawdust is remaining on the surface, then you are free to move ahead with oiling once it has dried.
If there is still some residual dust or dirt, which is unlikely if you've sanded and pressure cleaned it, then it is worthwhile giving it a scrub with some Deck Clean and a Deck Scrub Brush.
Let me know if you have any further questions and don't forget to share some photos when it is done.
Thanks Jacob. I did sand with a 120 grit. See attached pic. Does the sanding look ok?
It doesn't look too bad, but I can see some patchiness that could show through once oil is applied.
I'd suggest giving these sections another light sand to even things out a bit before applying your coat of oil.
Thanks Jacob. Is it better to go to a 80 grit and then to a 120? Or do i just use 120 to remove the patchiness
120 grit will be fine, you may just need to go over it for a bit longer.
Jacob, i am having struggling to get rid of the patches on the deck with the ozito detailed sander I have.
I went to bunnings yesterday and they recommended the 18V Cordless Ryobi Belt Sander that I purchased.
Haven't use the belt sander previously and read that it is pretty powerful piece of equipment.
Any tips on how to use it without damaging the deck?
Should I consider buying another sander such as thw random orbital?
Mitesh
I wouldn't suggest using the belt sander on your deck as it doesn't need resurfacing. There are just some areas that look like the previous coating wasn't applied evenly. You could change to 80-grit in your detail sander, but I wouldn't push hard as you could scratch the timber. A belt sander is really a bit aggressive, and you risk damaging the timber. I would scrub the deck down with Cabot's deck clean and see if it minimises the blotchy areas. If you were happy with the look of the deck before, then you've now improved it by sanding the areas. Give it a good scrub and you might like to post some images to check with us before coating.
Thanks Mitchell.
I got 120 grit sandpaper for the belt sander. Is this worth a try or too aggressive for the deck?
You could try that @MSD, though I'm not overly convinced your deck needed sanding in the first place. The current coating looks a bit mottled and is potentially deteriorated in some sections. Ultimately, sanding the coating right back to timber would give you the best results, but that is not something you'd want to do every 12 months. It's normally only for a deck that has been neglected for years.
Personally, I would give it a good scrub down and re-coat it. The new coat will even out a lot of patchiness. If you are unsatisfied with the result, you could consider sanding it back to timber.
Mitchell, i tried sanding with the belt sander. Tried the 120 grit and then went down to 100. One particular area is taking extremely long with the belt sander to strip back the original stain.
Is there a reason for this?
It could have just been a very thick coat in that area @MSD. If you've been using the sand paper for a few hours, it might need to be swapped out for a new piece; they tend to lose effectiveness after some time.
Finally managed to get the deck completed. Thanks everyone at Bunnings Workshop for their help and support.
That looks sensational @MSD!
Well done and many thanks for sharing your results.
