How to make this birdbath stand?
Coolaholigah
Building a Reputation
Can anyone tell me what kind of wire mesh this is and how to make a ‘column’ out of it please. I have a flat cement platform I can put it on. I imagine one can purchase the stones to fill it with
thanks
Re: How to make something like this birdbath stand?
Hello @Coolaholigah
Ideally, you're after mesh that has a gap of 25mm between wires like the Saxon 50 x 25 x 25 x 0.9 2.5m Wire Mesh. In order to create the circular shape, you'll need to use a guide such as a basketball or a large cover of a plastic bucket. I recommend rolling the wire mesh on the ground while the basketball is inside. When you have the length that you need, you can cut the wire mesh with some side cutters. The edges can be secured using Whites 1.57mm x 30m Handypak Galvanised Tie Wire while twisting it with some pliers.
I suggest having a look at the pebbles and stones in stock at the store as there are a few to choose from. However, if the sizes you are after are not present you can order them at the special orders desk. There is also the option of using wire mesh with smaller openings.
Please make sure to wear gloves and safety goggles when you are assembling the wire cage.
mich1972
Home Improvement Guru
How great are those Gabion Birdbath Stands !! Secure place for lizards to hide and shelter from predators. Can’t wait to see what you create @Coolaholigah
Great advice @EricL !!!! I wouldn’t mind making one for our Garden 😀
Thanks. I’ve never heard the term Gabon before. That’s helpful thanks
HI @Coolaholigah
The word gabion generally refers to a cage filled with rocks. Thats why you sometimes hear the word gabion fencing which refers to a very specific type of fencing. Here is an excellent featured project that has a gabion base on it - Gabion wall bench seat build project by @tony1982.
