Hello, wanting some help as i've ran into issues. I've listed two photos below and one is beforehand (empty hole) which installing the supplied wall plugs on the box but drilled out the hole too big and now it doesnt sit properly. Tried to fill it with exterior liquid nails and install new ramset 12x60mm and let is set for a day. Tried installing bracket and hose reel back on and the top two bolts started to slide out very easily due to the whole being too big and even with the liquid nails being set. Out of ideas, do not want to fill it again and have the same issue. thinking of just moving the bracket higher so that it covers all the holes, but if i drill a hole just above or below the hole, would that area be "weak" due a hole being basically next to it? Ive installed the one at the back yard fine without issues. the panels are the hebel power panel XL
Items used:
1. Holman 20m Retractable Hose Reel with Spray Gun
2. Selleys 350g Liquid Nails Exterior
3. Ramset 12 x 60mm RamPlug Nylon Anchor - 5 Pack
4. Zenith M8 x 75mm Hot Dipped Galvanised Hex Head Coach Screw
