I’d like to put up a sign onto an exterior brick wall, but I don’t have a drill and don’t want to get all the kit just to put up this one sign. The sign is aluminium composed and will have pre-drilled holes. Is there a way to do this? Thanks
Hi @Kaileybum,
It would be helpful to know how heavy and how large the sign is. For smaller, lightweight signs, a construction adhesive could do the job quite well, especially if the surface is clean and dry before you apply it.
If you’d prefer the sign to be screwed in place and don’t want to invest in all the tools, you could consider getting someone to help with the install. Services like Airtasker or Hipages can connect you with someone who has the right gear and experience to get it done quickly and securely.
