Helping my son and daughter-in-law with a roofing problem on their "patio' which leaks like a sieve due to poor roof installation.
Problem: It was originally intended to be more like a simple, open pergola with no roof. The structure's rafters are dead flat, ie there is no run built into the patio, but the previous homeowner put a polycarbonate roof on it with no purlins / battens and therefore no slope for drainage. It's attached to the house along its Northern and Western sides, so when I re-roof it I need to make a North to South run in the roof so rain can run off into a gutter or into the garden at its southern end.
Apparently (per the Suntuf installation guide) this should be a 5 degree slope. Which means a 235 cm drop along its 2670mm length.
MY MAIN QUESTIONS:
1) Do I really need so much of a slope it seems excessive!? If not what is the smallest I can get away with?
2) What is the best method or achieving it:
Do I add "purlins" of the appropriate heights perpendicular to the existing rafters (rafters run north : south)...this sounds challenging because the purlins would need to be very wide, ie the northern most purlin would need to be 23.5cm higher than the top of the patio's rafters (!!), then successively narrower purlins to achieve the slope needed until I reach the southern end of the patio?
OR
Do would I be better off adding a tapered beams running along the top of the existing rafters to create the slope I need, then add standard purlins on top of those beams to attach the roofing sheets to?
I don't love the sound of either of those options so maybe someone with far more knowledge than I have can give me a better idea!!!
Any advice welcomed! Photo taken from the South East corner of the structure attached
Cheers
Tim
