How to replace faulty Lytworx power adapter?
blaister
We have had our lights up for almost a year and they took some time getting right. We recently went to turn them on but they won’t stay on, rather flicker. We’ve tried lots of different trouble shooting and think we’ve narrowed it down to the power supply. we really don’t want to have to take all the lights down to return to Bunnings and hoping we can just get a new power adapter. Any ideas? 💡
Re: Lytworx Power Adapter Faulty
Hi @blaister,
Have you discussed this issue with the store of purchase? I'd recommend you take your proof of purchase and the power adaptor into the Bunnings store and speak to a manager. Since the product is likely still under warranty and if you can explain the situation, I trust the manager will do their best to swap the power adaptor over.
angietiare
Re: How to replace faulty Lytworx power adapter?
Hi there,
Really interested to know if you managed to find a suitable adapterreplacement? We are having the same issue, the adapter for our Lytworx Festoon lights (less than a year old) has blown. I've searched high and low online but can't find the exact specs, particularly matching the output voltage of 26V which is pretty crucial! All the other specs I can match.
I even contacted Dats Pty Ltd which was listed on the tag on the light lead itself, but no luck there.
Really hoping can just resolve the issue by getting another adapter! Seems simple enough 🤔 would be a shame to waste money, and the lights if we can't power them.
 Cheers!
AlanM52
Amassing an Audience
blaister
The faulty transformer secondary voltage is 24V DC and the wattage is 9W.
I = P/E
I = 9/24
I = 0.375A or 375mA (Transformer current rating).
With that bit of trivia out of the way let's move on.
Tools:
Multimeter.
Click Hobbyist Multimeter (0381004)
Cutters.
Strippers.
Knife.
Screwdriver set.
Terminal block - Deta 20A 12 Terminal Connector Strip (4332100)
Purchase:
24V 1A 24W Power Supply Adapter AC 100V-240V to DC 24volts Power Adapter Universal Switching 24V Christmas LED Light Strip
https://tinyurl.com/33894dys
(Or similar)
Cut the plug off the LED lights and strip the ends - twist together.
Cut the plug off the new transformer and strip the ends - twist together.
Cut off two terminals (pair) off the strip.
Polarity check:
We must connect power supply positive to LED wire positive.
Same for the negatives.
Transformer polarity check:
Make sure the transformer wires are separated.
Plug in and switch on transformer.
Set multimeter to DC 200 and check the wires.
If you get a negative reading swap the probes.
The transformar wire on the black probe is negative.
Identify that negative wire with a bit of sticky or masking tape.
LED lights polarity check:
Set the multimeter to diode mode.
Touch the red probe to one wire and the black probe to the other wire.
If the LED lights up, the probe that's touching the strip's positive wire is red (positive) and the probe touching the negative wire is black (negative).
If the LED does not light up, reverse the probes.
Mark the negative wire.
Connections:
Insert the transformer wires into one side of the terminal block.
Connect LED light wires the other side observing polarity.
Cheers
Welcome to the Bunnings Workshop community @angietiare. It's sensational to have you join us, and many thanks for your question about festoon lights.
I'm sorry to hear you've had an issue with your lights. If your Lytworx Festoon lights are less than 12 months old, they should still be covered under the manufacturer’s warranty. I’d recommend returning both the lights and the adapter to the store you purchased them from, along with your proof of purchase. The team in-store should be able to assist with a replacement or offer a suitable solution.
