Good morning,
I just moved and bought a heap of timber planter boxes with trellises. I will be honest, they were cheap. I plan to plant a dwarf citrus plant in each and other vegies (organic) in the other. I have a disability so paint brushing isn't an option. What would be the best spray option? Buy a tin of ? clear sealer or protection coat. Buy a spray gun and do it that way? What protection paint should I use? Does anyone have an idea of a small spray gun that doesn't need a compressor. Once completely sprayed, I will line the inside of the tubs in heavy duty plastic and drill some holes for drainage. I think, if that is the right way to go? Novice to beginner gardener.
Thank you
