Merbau slat fence
CagsMac
Budding Contributor
Merbau slat fence
Hi all, for my first ever building task, I tackled a merbau slat fence around this new slab I just had laid. Purpose is to increase the usability of our courtyard and so far I am pretty happy. There are a couple of rookie errors on the fence like not measuring correctly and the top slat being 10mm above the top of the post. A post cap has hidden that somewhat and the gate wasn't level so I had to adjust the slats to level. But on first glance it looks good and hopefully most won't notice unless they are looking for issues or I point it out. Intention is to continue a screen along the front wall for some added privacy.
I wanted to share the progress because I have been looking all over the internet for ways to do this style of fence without going to the ready made posts with slat inserts etc. Hopefully it will help someone else. I have no experience with this, just asked a couple of tradies along the way where I wasn't sure about something. If anyone has any questions, fire them away and I will hopefully be able to provide the answer you seek.
Scott MacFinished fenceFinished fenceCourtyard beforeCourtyard beforeSlab and postsSlab and postsGate (Was the right way up in my photos ??)Gate (Was the right way up in my photos ??)Happy I got to buy a drop saw :)Happy I got to buy a drop saw :smile:
Re: Merbau slat fence
Well done @CagsMac. I'm sure your project will have loads of admirers. You should feel really proud of what you have accomplished.
Many thanks for sharing.
pats6182
Junior Contributor
@CagsMac What posts have you used?  The ones that have slots to insert the timber slats?
CagsMac
Budding Contributor
Hi @pats6182, I used 50mm steel posts. I was going to use aluminium but they didn't have enough in stock. I just tacked some 20mm angle on each post so I could secure the slats from the rear so you wouldn't see exposed screws on the outside. let me know if you want some close up pics and I'll get some for you.
pats6182
Junior Contributor
Hi @CagsMac do you mind sending clsoe up pics.
Thanks heaps
