Outdoor Kaboodle kitchen
RayaJane
Good afternoon guys.
I’m looking to build an outside Kaboodle kitchen.
I’m at a loss on how to design the BBQ drop in section.
It would seem I’m missing something? Or are people altering an aspect?
I just want draws into one side 900
then maybe some cupboards under the bbq and then I’m having a fridge under the other side. Very simple.. well so I thought. All Kaboodle bases are 720 high, so how do you get the bbq drop in section? Raise the sides? Get cupboards n cut down? Please enlighten me, as I am in fear I’m over complicating the situation.
clh
Re: Outdoor Kaboodle kitchen
Looks amazing well done!!
Just wondering what you used for the cabinet and drawer fronts? Also a kaboodle product that you painted?
mmasci
Building a Reputation
@clh
I used Kaboodle door and drawer fronts that come unpainted or “raw board”. Then I painted it with an  external semi-gloss house paint for protection.
dabba
Looks nice.
Q what clearance did you have between the sides of the free standard bbq and cabinets/back wall?
thanks
Hello @dabba
Thanks for sharing your question about mmasci's outdoor kitchen. Let me tag @mmasci to make them aware of your kind words and question. Looking at the final finished photo, it appears to be a large gap at around 50 to 60 millimetres in length. But let's wait for @mmasci to confirm.
mmasci
It is about 50mm. Note the wall behind it is a 200mm solid concrete block wall. So I wasn't worried about heat or fire.
The BBQ design has a feature where the very bottom sticks out 50mm so if you push it up against any wall it leaves that air gap.
Be aware of your particular BBQ you choose as to makes sure when you open the hood it doesn't hit the wall behind it. I think most BBQs the hood hinges such that the hood doesn't stick out too far past the back of the BBQ itself.
It is important to have the heat resistant materials or the required gap away from the edges of the BBQ.
Hello @mmasci
Thank you for that extra information about your outdoor BBQ. Let me tag @dabba to make them aware of your answer and recommendations.
