Outdoor kitchen
darryl7
Junior Contributor
Outdoor kitchen
darryl7
Junior Contributor
Re: Outdoor kitchen
Yes it has plastic spacer legs on each corner raising it about 25mm of the bench.
Re: Outdoor kitchen
Thankyou @darryl7 @ for all of this very useful information. I really appreciate your time and inspiration
JustinS
Junior Contributor
Re: Outdoor kitchen
Well done this looks great @darryl7 !
I’m about to build an outdoor kitchen although a bit smaller.
Did you build this on top of the decking or build the kitchen first and the decking around it?
I already have the decking in place and am wondering whether I can build straight on top, or I’ll need to recut the decking and fix the kitchen framing to the concrete slab underneath.
Cheers, Justin
darryl7
Junior Contributor
Re: Outdoor kitchen
Thanks for the compliment Justin. Yes i biult the kitchen straight down on top of the deck. There are four 250mm long bugle head screws spaced out in the bottom of the cabinets into the decking to hold them from moving around as i had no where to fix them through the back of the cabinets.
JustinS
Junior Contributor
Re: Outdoor kitchen
Great thanks mate! @darryl7
Re: Outdoor kitchen
Hi @JustinS,
Please keep us updated on your progress with the outdoor kitchen as they are particularly popular within the community. You might like to start your own discussion about your construction so we can all follow along.
We'll be looking forward to hearing more about it.
JustinS
Junior Contributor
Re: Outdoor kitchen
Thanks @MitchellMc
I’m trying to decide on what material I’ll use for the external cladding and cabinetry. Can I use marine grade ply and then paint this? Would I still need to clad with a blue board first? Thanks.
Re: Outdoor kitchen
@JustinS,
You can use marine grade ply and then paint it for the cabinetry. I might need more details on what you intend to clad with blue board to offer an answer on whether it is required,
JustinS
Junior Contributor
Re: Outdoor kitchen
Thanks @MitchellMc !
@darryl7 what type of material did you build your cabinetry from? Cheers.
darryl7
Junior Contributor
Re: Outdoor kitchen
I built my cabinets from formply, its usually used to hold wet concrete so its strong and doesnt mind getting wet. I did have to scuff up the surface a bit to get the paint to stick to it.
