Hello,
I may be missing something obvious but here goes.
I am building a picture frame deck and have 135mm x 19mm Spotted Gum decking boards. What should the measurement be from the outer frame to the next joist to be able to support the picture frame (with a slight overhang of the decking board and a facial board)?
What should i be considering here?
Thanks.
Hi @Alan__,
It's a little bit tricky to work out exactly where the next joist should be to allow nailing off of the picture frame and decking boards. Since the picture frame board is 135mm wide, you'll need a couple of 45mm spacers to nail into and then your first joist to capture the ends of the decking boards. Instead of having the two spacers at nailing points, you could just make it one noggin.
I hope the rendering I've created for you below makes it more straightforward.
No problems @Alan__ . Reach out if you need further assistance. As chance would have it, I'm outside in the blistering heat, laying decking boards this very moment.
The framing is now complete. Thanks again for your initial input.
Could you please recommend any resources or provide some tips as to how to approach laying the decking boards for a picture frame decking? i.e. do you do the picture frame border first then fill internally with the boards or just place the first board down and go from there? Also, any tips to get the first board straight for a freestanding deck would also be appreciated.
Thanks.
Hello @Alan__
It's great to hear that you've made progress with your deck framing. Would it be possible for you to post a photo of your newly assembled frame and its measurements? This will give us a better idea of how it's laid out. We can then offer you a comprehensive recommendation on how to proceed. Below are a few things to consider when laying down your decking panels.
Let me call on @MitchellMc in case he has more suggestions to add.
We look forward to seeing the photos and measurements.
Hi @Alan__,
@EricL has it spot on. Start with your fascia board and work in from there. Once the fascia boards are attached, you can use spacers to set the position of the picture frame. Once that is in place, you can start laying your boards. I'm using these Macsim Fasteners 150 x 100 x 5mm Yellow Full Shims on my deck.
I also came up with this handy little jig. I just took a scrap of the decking board and screwed a spacer into its side. I then pre-drilled two holes where I'd like my screws positioned. The jig is used to space the boards whilst also positioning your screws.
Thanks again for your continued advice and support.
Photo is below. We are currently levelling the frame using Tuffblocks and will be putting down drainage membrane and rock.
The frame measures 3057mm x 3827mm.
We are using 135mm x 19mm Spotted Gum.
We calculated a 10mm overhang with facia boards on three sides (not against studio).
There is a 400mm gap between joists (90 x 45).
Could you recommend a mitre saw keeping in mind that it will only be used for this project?
The jig was a great suggestion as well and will look at doing the same.
Thanks again.
Hi @Alan__,
What did you need the mitre saw for? Are you intending on cutting all the boards to length with it before laying them? If so, you'd be much better off laying them all and then coming back with a circular saw and cutting across all the ends in one straight line. Much easier to get a precise uniform finish and a lot less work. Otherwise, the budget-friendly Ozito 210mm 1600W 8¼" Compound Mitre Saw would be fine for a one-off job. I've used a similar one for many years on multiple projects.
As it is a picture frame would how would it be possible to do as you suggest with the circular saw?
Thanks.
