Picture frame decking frame dimensions?
Alan__
Building a Reputation
Hello,
I may be missing something obvious but here goes.
I am building a picture frame deck and have 135mm x 19mm Spotted Gum decking boards. What should the measurement be from the outer frame to the next joist to be able to support the picture frame (with a slight overhang of the decking board and a facial board)?
What should i be considering here?
Thanks.
Re: Picture Frame Decking Frame
Hi @Alan__
I believe @MitchellMc's suggestion takes into account that one side of the picture frame panels will be removed temporarily and it is on this open side that you will cut the excess panel lengths with the circular saw. However, if you are laying the panels in a staggered formation then using the Ozito 210mm 1600W 8¼" Compound Mitre Saw will make cutting single panels easier.
@EricL is correct @Alan__. You'd leave one of the picture frame boards off the end and run the circular saw along to cut all the boards to length. Set the depth on the saw so it only cuts through the board and not into the frame beneath. You might like to leave off the two exterior boards that have the 45-degree cuts on them that make up the picture frame to ensure you don't cut through them.
Alan__
@MitchellMc  @EricL
Thanks for the advice.
I will let you know how it goes.
Cheers.
