Hi everyone,
I’ve had a peruse of the discussions on decks which are brilliant – I still have a couple of questions.
I’m wanting to build a small deck under our entryway / portico. I’ve attached some photos of the space and the inspiration.
1. Do I need ledger boards along the inside brick walls? I’ve seen quite a few people just using angle brackets to bolt the joists directly into the concrete.
2. I was going to use pedestal foots half way along the raise the joists, however, given it’s concrete, will angle brackets bolted to the concrete do the trick?
3. I’m wanting to picture frame the whole deck, though the corners of this space are a bit tricky, does anyone have any advice?
*the only error in the picture framing image is I’ll be putting the edging on the outside, this image has it as part of the upper frame.
