I hope to do it upstairs from the window, tried high pressure water gun, but my Ozito was not powerful enough. Thanks for the suggestions.
Hi @Ton,
To clean leaves from your clear roof pergola, you could try using a garden hose with a jet nozzle attachment. Unlike a high-pressure cleaner, which is more effective at close range, a garden hose with a jet nozzle has better reach and can blast the leaves off more effectively from a distance.
Additionally, consider using an All Set Cobweb Extension Broom with an extendable handle. This tool allows you to physically push or sweep the leaves off the roof while working from the safety of your upstairs window. Combining these two methods should help you clear the roof efficiently without needing to climb onto it.
