Hi @auroracrystals,
We have this handy guide on our website on How To Install a Pond Pump, which should answer many of your questions about installing a pond pump.
There is also this article from @Adam_W on How to install a garden pond, which provides some great information.
If you had specific questions about the process, could you please let us know some details so we can assist?
Thanks Jacob
We have just moved to a new house which has a waterfall and pump that does not work. we are trying to find actually what we need to have the water fall working plus the water fall in the main pond working - many thanks for help, Brian
Hi Brian (@auroracrystals),
How big a waterfall and pond are we talking about here?
The two main things that are important are matching the pump to the volume of the pond and the height the water needs to be raised.
If you can provide some details about the rough size of the pond, the height the water needs to be raised from the pond to the top of the waterfall and maybe some photos, I could certainly assist you with selecting the right products.
Each pump is going to be slightly different in terms of its installation, but once we know what we can use, I can certainly give you some guidance on how to install it.
Hi Jacob
That's great thank you
How do I send a photo
Brian
I see the icon at the bottom to upload image
From the bottom to t
the top pond is around 1 metre from the bottom
In terms of volume, it doesn't look too large, so the main thing is the height.
If there is already a pump, it would be a simple case of filling the water feature to a level that allows the water to cascade down between the pools, then placing the pump in the lowest pool and attaching a hose that brings it back to the highest pool. You have an outdoor electrical point in place, so you would just need to plug the pump in.
If the pump is not working, then this AQUAPRO AP1050 Water Feature Pump would be a suitable alternative. You would just need to grab some AQUAPRO 12mm x 3m Anti-Kink Tubing and route it up to the top pool, then plug the pump in.
I hope this helps.
Further to the above I have found the inlet pipe at the bottom pool which is a small piece of garden hose and by putting a hose to this pipe the water comes out at the top pond.
However not too sure where the pump is, but the pump that you have indicated, which sits in the pond. could this be plumbed into the hose at the bottom pool where the pump will be sitting, and if this can be done then it will pump the water up to the top pond.
Many thanks for all the help
Have you got a photo of the entrance to the inlet pipe that you can show us? What is its diameter?
I imagine there would be a way to simply run the outlet hose from the pump into it, but we'd have to see it and know some details to be confident.
You may just need to use some Clear Vinyl Tubing and their joiners, or something like that to connect the pump into the inlet hose.
I will wait and see what you are working with and assist further.
In the photo of the pond that I sent, you can see a patch of green at the bottom of the main pool and that is the hose which is just a piece of garden hose which is 15 mm on the outside
Appreciate all the help and feel that we are now getting somewhere
Seems like you should be able to just grab a length of Pope 13mm Vinyl Tubing and then use a couple of Kinetic 6-16mm 316 Stainless Steel Hose Clamps to lock it onto the outlet on the pump and the hose in the fountain.
The diameters are close enough in size that you should be able to slip the tubing over the pump, which uses a 12mm hose, and into the 15mm hose. With the clamps, they should stay where they are supposed to.
Hopefully, that is the last step, and your next update will be some photos of your now operational water feature.
Yes that sounds like the best option
