need to clean the eaves of our house and the outside which is rendered, what products and how to clean
Hello @Mazie
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about mould.
I suggest using 30 Seconds 5L Outdoor Cleaner Concentrate in combination with an All Set 270mm Indoor Broom its soft bristles will not damage your wall or eaves when used as a brush. If you have access to a pressure washer you can use it on your rendered wall, but do not use it on your eaves. A standard garden hose will be enough to rinse the surface of the eave. For continued care I suggest using 30 Seconds 5L Spray And Walk Away Concentrate on your rendered wall. However, please do not use it on your eaves as rainwater will not reach it.
