Bedside table halo with Grid Connect automation
CSParnell
Experienced Contributor
I have been using a bedside lamp with an Arlec Grid Connect globe automated to turn on for a minute on early mornings for work though the issue being even at low dim it's still to in your face and waking the wife up as well so I thought to add a spare led RGB strip I had to the underside, backside and facing side of my bedside table the  plug it into an Arlec Grid Connect power adapter so I can automate times it comes on and for how long. I could also go as far as using the ensuite Light Globe "on" as a trigger to turn it off. The effect is much better and the light level is below bed level.
The same could be achieved with the Arlec Grid Connect LED strip lights as well.
Re: Bedside table halo with Grid Connect automation
HI @CSParnell
That's a great idea and is not as bright as a standard LED bulb. Did the LED strip come with a remote control? Perhaps you can control its brightness even before it turns on or does the unit reset every time the power adapter turns it off? My son's room has the Click LED light strip and is fantastic in the evenings when he turns the lumens down.
Thank you for sharing your LED strip lighting idea.
CSParnell
Hi @EricL, the LED strip can dim down but it is not a grid connect model. It does hold its settings though so how I have it set it stays that way after power is turned off.
I have not used the grid connect LED strip but I would assume you are able to automate light intensity so you could turn that intensity up over a set time for a gentle wake up.
Hi @CSParnell
Thanks for that extra information, I'll keep that in mind when I  purchase my own LED set for my desk.
CSParnell
I changed the on/off over to a schedule so you could set up a whole week's worth of different times if you like
