I have a convection panel heater (no fan) that can be used on wheels or wall-mounted. The warm air rises from the top of the heater, not the front, & the front panel gives off radiant heat.
I also use the fan on reverse mode to push the warm air back down.
I'm working out the best position for the heater.
Putting it under a window seems to be popular advice but I've also read that placing it against an internal wall is good, as the internal wall warms up & retains the heat for longer.
Does anyone have any thoughts/advice?
If it was safe to coil cables up whilst drawing higher currents (as heaters do) wind up extension leads wouldn't carry warnings not to use them whilst coiled up!
So Inductance, what is it and how can it be dangerous? when two cables are in close proximity with AC voltage passing through them they can "induce" voltages in the adjacent cable by electo magnetic radiation (a great way to see this happening is if you have a power supply for something like a laptop with an led indicator in it, unplug it from the laptop first and then from the power and you will notice that it takes time for the LED to go off. that is because as the voltage goes off from the socket, the collapsing voltage induces a voltage into the coils of the transformer generating a voltage that keeps the led on and then when that voltage begins to collapse it induces a voltage yet again and so on till it has decayed enough for the led to go off and that's why the led takes time to go off.
A transformer is simply coils of wire so by coiling a cable you are creating a simple version of the transformer but you are constantly feeding it with power and the induced voltages can conflict with the input power and the result is generated heat. ultimately you can end up with the situations shown in the link I posted earlier.
Look I may be being simplistic in my explanation but the danger is present, how present I can't say but I would rather say there is danger than not and risk a fire with who knows what consequences. Would you rather play safe or just say what the heck and risk it?
Hi @Dave-1
A 2 bar electic heater can draw between 8 and 10 amps (in a domestic situation, that is quite high current) and you would probably trip the breaker if you had 2 heaters on the same circuit! I carry Public liability insurance to $50 Million and I recommend not doing this, how much do you carry if you are saying it is perfectly safe? I also linked to other sites that showed that it may well not be. Please be careful stating emphatically what is safe and what isn't because it comes down to who would be liable if things went pear shaped, you or Bunnings?
Evening @R4addZ
Just to let you know, I am a sparky. Have been since 1990. Worked in heavy industry, dockyards, technician with Telstra and It. I have seen inductance and consequences with it. Its one cable wrapped a few times, most work places have that in varrying degrees. Yes heaters do draw more current but even so several trurns would not be a concern. I know I will be having a chat to the sparkies at work and Elec engineers tomorrow to see their opinons (always willing to learn new things and change my opinions) but have been down this discussion path at work before
Yes we are geeks and testing this type of theory out somehow grabs out attentions.
Hi @Dave-1
Look forward to your feedback, I am only commenting on what I was taught as are you. But I lean to the side of caution as you probably do and find it safer to say no rather than yes! Just a point here is that I have a plug in electric Wok and just cooking the cable gets hot, how do you think it would go if I coiled that cable?
Goodmorning All
We see things differently
As much as I would enjoy to keep on with the discussion we arnt going to change our opinons
That is the good side of this forum, there are different views over how to and what should be. The answer that @Else was after is the main point of the thread. I perosnally like the heater to be on wheels, others like the wall or under the window suggestion. All are valid. Just different ways to go about it.
Until next time on a question ![]()
Hi Dave-1 & R4addZ
Thanks for all your comments...
Reading your different opinions is a great way for me to broaden my knowledge & to work out how I should approach sthg/solve a problem.
On the one hand, it's reassuring to read that something is probably ok (if it mostly is)... On the other, it's also good for me to understand the risks.
Even if they're remote, some are significant in their effect & as I don't have the expertise to judge many electrical scenarios, erring on the side of cautious is probably best with electrical things! I'm really grateful to you both though. I'm learning a lot!
