Hi, I have a Ryobi drill driver but it took forever to drill only the surface of the brick. I specially bought a drill bit for brick. Is this drill driver not strong enough for drilling brick? thanks
Hello @ritcho
Thanks for sharing your question about your Ryobi drill driver. I just want to confirm, did you change the function of the drill to hammer function? If you have a Ryobi drill driver there should a switch at the top that lets you change function.
Here is a link to our best advice: How do you drill into brick?
I also suggest having a look at this guide - How to drill into brick.
In regards to your current drill bit, did it overheat while you were using it? How deep did you drill into the brick? If the bit has overheated it's probably worn down the critical cutting edge of the bit making it more difficult to drill into the brick.
I propose trying again, but this time using the small masonry bit technique as a pilot hole and then drilling the larger hole. In regards to the type of masonry bit, I suggest using something from the Kango or Sutton range.
Hi Eric,
My Ryobi drill driver does not have a hammer mode. It seems that mine is for drilling wood, metal.. only. Thanks for your detailed information. I will try drilling pilot holes than larger holes.
Thanks so much.
Hi @ritcho
If you are drilling without a hammer mode, I suggest drilling slowly making sure that the drill does its job properly. Make sure to give the drill bit a rest period to prevent overheating.
