Hi all,
I need some help in relation to Expanded Polystyrene Cement (EPS)
I was planning to move a few power points/sockets in our house, but have discovered all the internal walls are filled with it.
I am on a tight budget and so was wondering if it is possible to use a hammer and chisel to clear a path, so to speak, from the current socket to about 30 below it, where I need it to be located to.
I don’t plan on having anything to do with the electrical wiring, just trying to reduce labour/hourly rate cost. The electrician that came to have a look for a quote said he would have to hire an edger or router (can’t remember which one) to cut the wall.
I’d turn the power off when I chisel into the wal to be safe, however I have no experience with EPS. It’s frustrating as I was also wanted to have my washing machine taps moved, but same problem. I don’t want to dig half the wall out and comprise wall integrity either.
Any information or advice would be enormously helpful because i feel really unsure about what my next move should be.
attached image of EPC for reference
