Hi community,
I'm looking to add insulation and moisture protection under a timber floor for a terrace house (ground level). The timber floor will go over joists that are suspended with a small cavity of around 400mm above a dirt floor.
As well as to improve the insulation, I'm looking to stop moisture and musty smells coming up through the floor. The solution I'm thinking of is to add a breathable waterproof membrane over the joists and create a bit of a hammock to hold the earthwool floorshield insulation. Pic attached of the kind of setup:
The product I'm looking at for the membrane is the Ametalin VapourTech Brane
It doesn't mention floor application, so I wanted to get some opinion on whether it would work for my situation?
Much appreciated.
