How to cut blinds to size?
PAULW2
Am looking at the
Practa 180 x 150cm 25mm White Aluminium Venetian Blind.
Can this be cut to a specific size ?  I need it to be 1780mm wide x 700mm drop.  Does Bunnings offer a cutting service ?  Approximately what would be the cost to cut to size if offered ?
Many thanks, Paul
Re: How do I go about getting blinds cut to size
Hi @PAULW2,
Unfortunately, Bunnings do not offer a cutting service for blinds.
I'd suggest you check out our range of Custom Made Blinds which can be made to the specific sizing you are after. These Riva 1515 - 1814 x 1815 - 2114mm 25mm Slat Made To Measure Aluminium Venetian Blind look to be your best option.
If you'd like to explore this option, head to your local store to speak with their Special Orders team. They will be able to assist you with the selection and ordering of the right blinds for you.
Have a look at Riva Custom Blinds for some further information.
Once received, you could also use our Curtain, Blind & Shutter Installation Service, which can also be arranged through your local store's Special Orders desk.
PAULW2
Many thanks.  Appreciate the information.
