Greetings!
I'm excited to venture out into my first home project build and hoping to get this right... lol... the first time. So very keen to get as much advice as possible.
As I already have done a bit of prep work, I have already acquired the panel, as well as some shelf furniture and a standing desk frame from Amazon that I will be mounting the panel to.
My questions came from me reading the Instructions and product description that came with the panel. It states that the product is pre-oiled, but states that I should use an oil and sealant before going to work on this. So just curious if anyone has any recommendations as to which products Bunnings carries that I could apply to the panel to give it more of a smoothed out finish. Is this just from an oil and sealant as the product sheet recommends?
Also, as the panel came at 1800mm, I will be trimming this down to about 1550mm to fit the space better, so I'm thinking I will need to sand the cut edge... or would it be better to cut a bit off each edge for more of a matching finish?
Also, as I'm getting used to metric measurements, what sort of mounting screws should I purchase... I would like to ensure that the panel is accurately fitted and secured to the standing desk.
A couple of other things that I intend to do is see if its possible using a router, to carve away a space underneath to mount a wireless charging pad under the panel so I could possibly trickle charge my phone just by placing it on the desk. Does something like this take away from structural rigidity of the product?
The more I add to this, the more questions crop up. So I want to leave this here and see what cool ideas y'all have. And I'm pretty sure that the answers supplied will generate even more questions.
Thank you for your time and look forward to your awesome answers!
