I have 3xsingle hung windows that won't stay up (open). The window will open- my guess is that the weights aren't attached to the drawstrings.
1) what do you think is preventing it from staying up (open)
2) are there some sort of 'stop/hold clips' I can buy to use as a stopper, this way I don't have to figure out how to solve the drawstring/weight mechanism
When I go on youtube the videos seem to be made in the US, their window frames it seems you can take off the timber side which then let's you see the drawstrings and weights inside. I can't see these screws/nails anywhere on the side for my windows.
Question: Any ideas what I need to do to see the drawstrings and weight mechanism. I guess then I could fix the mechanism if there's no easier fix?
This photo below shows the sliding part of the window
This photo here below shows that the sliding part of the window is propped up by these timber sides which are about 2cm in width. Do I need to pry these side planks open to get to the internal weight/drawstring mechanism? If so is it nails holding it in place? and so I would need a flat screw driver to make a wedge and hammer away until it becomes dettached to the larger plank of timber
