Can anyone please help me get my drawers working?
I've bought a house that came with some modular built in cabinets (brand unknown) that the previous owner installed, which includs soft close drawers. Two of the drawers were sticking, taking a LOT of physical effort to get them open, and then you really had to shove them to get them to close; they also made a weird scraping/crunching noise. Pulling the drawers out, the runners were tacky to the touch and covered with what looked like solid flakes of dried grease and a LOT of grit and sawdust.
I cleaned them off fully with a paint brush and cloth both damp with warm water and a litle bit of detergent, and dried them fully. The runners after were silent and working almost perfectly. To finish the job I sprayed them down with Selley's Ezy Guide Dry Lubricant. Hours later, the runners are sticky, incredibly resistant to moving, and make a weird mix of a scraping noise, a squeak, and a squelching noise when used. When I put the drawers back on it took as much effort as before to get them to open, and the soft close function would not kick in until the draw was basically already closed. I've got the same drawers twice the size holding heavy objects that work fine, so can't be the added weight, and everything's aligned good. It's the runners just jamming up when they get lubricated, which seems to be the opposite of what's meant to happen! Do I need to use a different lubricant, perhaps?
