I've made a wooden box with a lid, which will be used by young children (inspired by this YouTube short: https://www.youtube.com/shorts/b82yN588qzc).
I want to make the lid soft close, to prevent mishaps with fingers, and the lid is too heavy to be soft close with regular soft close hinges/cupboard braces - so I want to use gas struts.
I want the lid to have an 80/85 degree max opening, the box depth is 400mm, the lid depth is 33mm and the lid length is 357mm.
I measured the length of the opening and ended up purchasing two 325mm struts (https://www.bunnings.com.au/goliath-325mm-150n-black-gas-strut_p4230058) and brackets (https://www.bunnings.com.au/goliath-20-x-25mm-stainless-steel-gas-strut-bracket-with-ball-stud_p4230027 / https://www.bunnings.com.au/goliath-10mm-ball-end-bracket-strut_p4230085).
But when I installed the struts (like in the video), the lid wouldn't close. I also tried using a calculator online (https://www.gasspringsshop.com/gas-spring-calculator/) and had the same issue (it recommended a 332mm strut which likely impacted the placement locations).
I've uploaded a picture (the strut is currently not connected to the base since the lid then doesn't close) - can anyone help me understand what I am doing wrong here?
Hello @jarko
Thank you for sharing your question about your gas struts for your children's wooden box lid.
The reason your 325 mm struts would not allow the lid to close is simply that their compressed length is still too long for the short distance available between the mounting points when the lid is shut, which means the geometry can never work no matter where you place the brackets. Toy boxes and storage chests with shallow lids like yours almost always need shorter gas struts because the mounting points move very close together as the lid closes, and the strut must be able to fully compress within that space.
In practice, struts in the 180–250 mm range work far better, and several Bunnings options suit this style of box: the Goliath 185mm 100N Black Gas Strut, the Taskmaster 265mm Pneumatic Furniture Gas Stay, and the Prestige 250mm Silver Pneumatic Stay. To choose correctly, close the lid and measure the shortest distance you can realistically achieve between a mounting point on the lid frame and one on the box side; the strut’s compressed length must be less than this measurement or the lid will never shut.
The 185 mm strut usually fits compact geometries most easily, while the 250–265 mm options can work if that closed-position distance is long enough and you want a wider opening angle. Once you select a strut that can physically compress within your available space, mount the lid bracket roughly 70–120 mm from the hinge and the body bracket 70–120 mm below the top edge so the strut sits at a gentle angle when closed, giving you safe, smooth soft-close behaviour for children.
Let me call on our experienced members @Noyade, @Dave-1, @AlanM52 and @Nailbag for their recommendations.
Hi @jarko,
Looks good and I like your pocket holes.
Looks like you need to drop the strut down and make a spacer block.
Here is another dad that made a kids toy box.
Did the instructions say to mount with rod up.
Maybe have a look at this video.
With little fingers in mind I would replace those back hinges.
Galvanised Piano Hinge.
Cheers
Hi @jarko
The last time I had to install a pneumatic strut was also for a toy box and remembered how difficult it was. But it was important so little fingers didn't get smashed so, I had to persists.
The first point is which @AlanM52 has pointed out is to change the hinges to piano. This will prevent the lid from twisting as it's pulled down to close which, works against the strut pressure.
The next is length of the ram which, @EricL noted to use a shorter one and of the right lifting power and mounting points. I would follow his advice on these points.Nailbag
Good Morning @jarko
Well I just learnt a new thing 🙂 I havnt install gas struts on anything as yet but will file @EricL's @AlanM52 's and @Nailbag 's words away as they make a lot of sense.
Thanks for the advice, but needing to resurrect this thread after the xmas hiatus.
I ended up following @EricL's advice and returning the smaller struts to purchase the shorter Taskmaster 265mm gas stay.
I purchased 2 of the stay's and was intending on putting one on each side (to avoid the piano hinge requirement from twisting on close).
Measuring accurately per the advice is somewhat difficult as I can't access the inside of the box when the lid is closed as it's already clad and painted.
I added a spacer block following @Alan5's advice and tried installing the strut in a number of different 'random' locations, but have been unable to get the box to close once I add the strut. I measured down from the closing pivot point and have the top of the strut at the lowest point possible which still allows the lid to close (see images below).
Is there anything else or product I can try to get the same outcome? Is the issue still the length of the strut, or is there something I am not doing correctly?
You are so close to success, I propose lowering the position of the lower end of the strut. I understand that this will lower the maximum opening angle of the cover but it should resolve the gap that is currently being generated by its current position. I recommend lowering it another two centimetres and testing for a proper seal. I also suggest considering using Moroday 24 x 5mm x 10m Grey PE Foam Tape to serve as a buffer to prevent finger pinching.
Thanks @EricL,
Can you help me understand how I can lower the strut?
The top of the strut is as low as it can go and as far back as possible without hitting the frame.
See the images below showing the lid almost closed and the position of the top of the strut:
If you look at the first picture of your former post that showed the entire strut. I propose re-positioning the bottom of the strut downwards by 1cm. Give it another test and to see how far the lid is from the edge of the box. If there is still a gap, I suggest lowering the position of the strut again by 1cm and do another test. Once you find the sweet spot position the second strut in the same position on the other side.
@jarko - I followed the manual that came with the strut and installed like this - https://www.workshop.bunnings.com.au/t5/Living-and-Bedroom/Ottomon-with-storage/m-p/322411. This works perfectly fine.
Thanks Eric, I don't understand how this is physically possible as the strut cannot be lowered any further. It's at its lowest point possible on the lid.
I can try @J-P's setup and see how that goes..
I believe Eric is suggesting to lower the bottom mount on the box, not the top on the lid. That should work, but it's not an optimal solution.
Regarding @J-P's advice, I believe the orientation they showed is the correct installation method, with the bottom mount positioned further toward the front of the box. You'll see in my pool pump cover, on step 9, that's how I positioned the struts.
If I were to hazard a guess, I would say the correct mounting positions would be as I've marked below.
