Hi Bunnings Community,
I’m having trouble with some uneven surfaces on the architraves in my flat. I’ve tried paint stripper, scraping and sanding, and it has turned into a bit of a mess. I can’t continue sanding because the old paint contains lead, and even with a mask I’m worried I might be exposing myself to dust.
At this point, some areas are back to bare timber, others still have paint, and there are multiple layers visible. The whole surface is patchy and bumpy.
As a solution, I was thinking of sealing the entire architrave with Peel Stop or Dulux Sealer Binder, then applying an undercoat in two stages — first spot-priming the bare timber, then doing a full undercoat over everything. Finally, two coats of topcoat.
Is this a good approach?
Any other suggestions for dealing with the uneven surface? Also, what undercoat would you recommend?
Thanks!
