When our front verandah was tiled a few years ago there has been some grout hazing ever since & it’s difficult to remove. Can someone please recommend a suitable product to clean this up without damage to the tiles & the existing grout?
Welcome to the Bunnings Workshop community @Mitch16. It's fantastic to have you join us, and many thanks for your question.
Have you ever removed any of the hazing, and do you know if your tiles are sealed with anything? Removing efflorescence normally requires some type of acid, and that could negatively affect your tiles sealer. There are products available for this purpose, like Crommelin 4L Efflorescence Remover. Still, you might like to start with something a little less aggressive such as a dilute solution of white vinegar and water. Apply the mixture and use a toothbrush to agitate the hazing. If the hazing is on top of the sealer and tile, it should be quite easy to remove. However, I would hazard a guess that it is likely within the surface of the tile. If this is the case, you might need to do a thorough cleaning with the efflorescence remover and re-seal your tiles.
Thanks Mitchell...much appreciated. I have no idea if the tiles have been sealed but I’ll try & find the original supplier & check with them.
I’ll try the diluted white vinegar solution as you advised however can you please let me know the mix volume of the solution? with thanks
Mitch
Hi @Mitch16,
I'd suggest using a 50/50 mix of white vinegar and water. Please make sure to flush the area down with fresh water after your attempt.
Thanks so much Mitchell!
I have done my grout from davco easy grout they have colour inside at grout. After I’m done my tiles they become like colour they not coming off what can I do? thank you
Welcome to the Bunnings Workshop community @tony6. It's wonderful to have you join us and thanks for reaching out with your question.
What have you attempted so far? Have you tried any of the suggestions that @MitchellMc posted earlier in this discussion? It would be great to learn more about this so members can offer suggestions for the next step.
Stevie
Hi @tony6,
Let me also extend a warm welcome to the community.
In addition to Mitch's advice above, check out the reply from @EricL in this recent discussion - Help with discoloured outdoor tiles
Please let us know how you go with following the suggestions provided and let us know if you need more assistance. We're here to help.
@tony6 It looks like you forgot to use a damp sponge before the grout dried. Once it dries it's VERY difficult to remove! Normally when grouting tiles you work the grout into the tile joints, let the grout partially dry, then use a damp sponge to level the grout and remove the excess. When it is dry the light haze covering the tiles can be polished off with a DRY cloth.Solution 1The easy solution first - Try some abrasion with steel wool soap pads.Moisten the tile surface with a wet sponge then rub with a soap pad to loosen the grout.https://www.bunnings.com.au/morgan-steel-wool-soap-pads-12-pack_p4460951 Solution 2You could also try a 10% acid wash which is a weak mix of hydrochloric acid and water. (ALWAYS add acid to water, never water to acid)Try it on a small section of grout first to see if it works. Leave it on for 5-6 minutes to react with the grout. (Use an old toothbrush)Shopping List, if you don't already have these items2x 9L Plastic buckets (2 different colours recommended)https://www.bunnings.com.au/9-3l-assorted-multipurpose-plastic-buckets-with-spout_p4461010
1x 1L Hydrochloric acid https://www.bunnings.com.au/bondall-1l-hydrochloric-acid_p0960232
1x Pair safety glasses https://www.bunnings.com.au/protector-clear-ultralite-wraparound-safety-glasses_p5814707 1x Rubber Gloves https://www.bunnings.com.au/sabco-large-tear-resist-gloves-1-pair_p0065931
1x Brick cleaning brush https://www.bunnings.com.au/mr-clean-tuffmates-brick-and-concrete-brush_p4460045
2x Boxes of Baking Soda from the supermarket. ($1.20 for 500g box in IGA)
Fill both buckets with 5L of water. (Litre markings on inside of bucket)
Put on the safety glasses and rubber gloves. ** Acid can be dangerous if not handled properly! **Carefully add half a bottle of acid (500ml) to the first bucket of water. (Makes 5.5L of 10% strength acid wash)Use the brush to apply plenty of acid wash to the grout you want removed. Leave it for 5-6 minutes then use the brush to shift any remaining grout. Clean sections of say 10 tiles at a time starting at the far wall, working backwards toward the entrance.CleanupAdd 500g box of baking soda (sodium bicarbonate) to the 2nd bucket and stir until dissolved. Mop this solution over the treated area when finished to neutralise the acid then hose down the verandah.Any leftover acid wash must be neutralised with baking soda solution before disposal.
Thanks so much for your advice…this was done by a professional tiler nit me I might add! It’s too long now to revert back to him so I’ll give your suggestion a go.
It's great to see you've received some excellent advice from the knowledgeable @Walzz.
Please keep us updated and reach out if you need further advice. We're here to help.
Hi Tony
Its not an issue with the tile or the skills of the tiler. Its a natural phenomenon which affects tile exposed to moisture.
Welcome to the Bunnings Workshop community @dilruksf. It's amazing to have you join us, and many thanks for jumping into the conversation.
Do you think @Tony's issue is the same efflorescence problem that the original post @Mitch16 is facing? The only reason why it appears this might be grout haze instead is that he had only recently installed the tiles, and I can't imagine that the tiles have had enough time to build up mineral salts on their surface.
We're keen to hear all about your projects and plans around the house and garden. Please let us know anytime you need assistance or have something to share.
Do you need assistance @michael6?
If you could please let us know what you are experiencing, we would be happy to help.
Welcome to the Bunnings Workshop community.
