How to repair detached ceiling plasterboard?
nugley
Building a Reputation
I noticed that my ceiling has shadow lines and when inspecting from inside my roof cavity there are areas of my ceiling that have detached from the ceiling joists where I can fit the tip of my finger in between. This detachment can be observed across 3 or 4 ceiling joists and I've noticeable this in two areas that are more open spacd. I'm just wondering if it's still possible to re-screw or whether the ceiling plasterboards need replacing?
I suspect the detachment occurred from old termite damage to the walls where the tiled roof was sitting on the homes' brick veneer back in 2014. The roof was hoisted and the walls repaired. Over time the detachment probably just got worse. The place is relatively old as it was built in 1988.
Keen to hear the community's thoughts.
Re: To rescrew or replace - Ceiling plasterboard detachment
Hi @nugley,
You’ll most likely be able to repair this without replacing the ceiling sheets. Use a scraper to carefully open the gap between the plasterboard and the ceiling joist, then apply some stud adhesive between the timber and the back of the plasterboard. Once that’s done, prop the ceiling back into position from below using an acro prop or a length of timber to gently push it up until it sits flush again. Then, re-screw along the ceiling joists to secure the plasterboard in place. The combination of adhesive and screws should hold it firmly.
If the ceiling joists are a bit sparse or uneven in that area, consider adding extra timber noggins between the joists to give yourself more solid fixing points. This will make for a much more secure repair.
If you can share some photos showing how far the plasterboard has dropped, that would help the community determine whether it’s still in good enough shape to re-fix or if replacement might be needed. But if it’s only sagging slightly, it should be perfectly possible to reattach it successfully.
nugley
Here are some photos of the ceiling sag in the roof cavity as well as photos below where the sag is. It's mainly these two spots. They run across a few joists. One of them is in the middle of the dining room and the other is around the kitchen. No water stains below and paper on the back is in tact and decent condition.    
That's entirely repairable as per the above method @nugley. Apply some healthy dabs of stud adhesive and push it between the ceiling joist and the plasterboard. Push the sheet back up into position and then fix it with several screws to hold it in place.
nugley
Thank you Mitch. Yes, for one of the spots, I could fit a whole finger (approx. 25 mm). And looking at the ceiling below you can see shadow lines, but there's only two sheets affected by the sagging. I had a builder advise me that the whole ceiling needed replacing, but my colleagues (who are serious DIYers) thought otherwise, which is why I came on here to ask.
I tried the method you suggested along with using a damp cloth to remove dust, dirt and grime. And it looks like it's now pushed back in position. I re-screwed every 40 mm, but I might put more in so that they're spaced out every 20 mm.
If you've placed a screw every 40mm, I'd say that's more than enough @nugley. I think every 150-200mm would have been sufficient. I would not add any more, as you risk cutting the sheet in half with screws, or at least, weakening it along the screw line.
nugley
Thank you Mitch. Sorry, I was meant to say every 40 cm. But I've now added more screws so that they're 20 cm apart. From the sounds of your last message, every 20 cm is sufficient. Thank you for the advice Mitch. Appreciate it.
Dave-1
Community Megastar
Good Evening @nugley
A bit late to the party :smile: But my loungeroom ceiling was as bad as yours if not a little worse, I could fit my fingers up to the first knuckle under the joists. I went a different repair route tho as the plaster would not budge and I was concerned about breaking/snapping it and then be up for a new ceiling. I didnt use a lifter tho would now :smile: This was the first time I had worked on a ceiling.
This end of the loungeroom ceiling joists had the "gap" I think from previous water damage but the look of it.
If you look at the ceiling you can see how I repaired those dips you have, it was a fill and feather exercise. The dips only extended as far as you can see into the room. It wasnt too hard to do other then sanding over your head. This was in 2014 and there is still no indication that the plaster isnt level :smile: Dodgy? mmm Nooooo It worked :smile:
You can see the ends of the fill on the ceiling. My only note for you is to be cautious moving around in the ceiling space as you dont know what the power is terminated like.
So my suggestion is to fill and feather :smile: How did you lift the plaster back to the trusses?
nugley
Thank you Dave. Appreciate your reply. I used adjustable sheet props. I was able to fit multiple fingers between the joist and board about 25mm gap in one spot. There are two joists where I didn't bud up the sheet right up to the joist but the rest I was able to bud up. Basically the old glue and screws just failed.
Thankfully I'm quite comfortable moving around in the roof cavity since I lay rat baits every 12 months and check for any roof leaks. I actually lay my snowboard across joists when I need to reach the corners and edges of the roof cavity.
Just wondering, after your fill and feather exercise did any cracks appear a couple of years later?
nugley
@MitchellMc @Dave-1 I have 2 spots where I glued and screwed but didn't screw the board flat against the joists. The glue has cured already, is there any way I can remove the glue and then screw the board flat to the joist?
