How to repair foundation pier?
Walter
Retired Team Member
Retired Team Member
Hey Workshoppers,
One of my senior friends called me over on this.
They have a brick house, well above the soil, sloped land (not a steep slope). Big space under the floor, supported on brick piers.
I think there's been some movement, and I've suggested an engineer, but thats costly, in the meantime, ONE of the piers has deteriorated, the remaining brickwork isn't firm (it rocks when I move it- so I think the soil has washed away.  `I checked the other piers, and they seem to be plumb (straight) via a spirit level, but I'm worried about this pier. Image below.
I think in the short time, something like this Uni-Pier might help, or at least be remedial.  I think we might have to get a better cement layer. My own opinion is to get a structural inspection done, but I want to get them reassured first.  I doubt home insurance covers this, because it's something people should inspected regularly.
Any advice from Workshoppers welcome.
Here's the photos:
This neighbouring pier is plumb:
Re: How to repair foundation pier?
Hi @Walter,
Many thanks for your question.
Yes, this is definitely something the owner should be engaging the services of a structural engineer for advice on, as it is likely there are a number of issues that will need to be addressed.
In the meantime, the Uni-Pier you have linked can offer some help but as they are a special-order item, it may take some time for them to be delivered from the supplier. I'd suggest using Gorilla 1.98-3.35m Galvanised Formwork Prop #2 as a temporary support with a suitably thick concrete paver as a base for the prop.
I just want to really drill home the point that this can only be used as a temporary measure and that the owner, as a matter of urgency, needs to contact a structural engineer for advice on remediation.
Please let me know what you think.
Walter
Retired Team Member
Retired Team Member
Hey @JacobZ
thanks for your response. Yes, I've advised the pensioner that a qualified structural engineer needs to inspect, and provide a report and reccomendations.
I wouldn't want to take responsibilty for something that doesn't work. The Gorilla prop looks good, and I can see it can be raised to the right height. I picked the UNiPier, because it looks like a good wrench or spammer can raise or lower it.
With the weather events of recent time, I think I'd rather they had some reassurance of a temporary support while they get a proper inspection, so I'll get them on it.
With any luck, an engineer will be out to visit them, and probably suggest a support pillar first and then do the remedial work.
Many Thanks.
