I have a roof leak caused by holes in the angle flashing which sits in the crevice where the window dormer protrudes from the main roof. The roof is a cape cod style tiled roof, and the steep angle makes it very hard to access from the outside. So I want to repair the rust holes from the inside of the ceiling.
If I use flashing tape the adhesive side will be facing outside, which is not how its intended to be used. Will the water and elements end up detaching the tape in the long term?
Is silicon a better choice, or will that create issues with water flow? I won't be able to smooth it from the outside, so can imagine it bulging outwards and preventing water from flowing downwards properly.
TIA!
