How can i remove all sticker glue from the walls and ceilings before painting?
Hi @paulcherian,
Welcome to Workshop. It's fantastic to have you join us. I trust you will receive lots of fantastic advice and inspiration from our community members, both for this project and for many to come in the future.
It might be helpful if you clarified what the residue is from. Did you remove wallpaper?
Thanks,
@paulcherian
I'm guessing kids bedroom? Kids love stickers!
I would use sandpaper and a sanding block. If any glue still stubbonly refuses to budge then an electric hand sander should finish it off.
Hi @RodBR,
Many thanks for joining in the discussion and sharing some advice. Much appreciated. Let me also extend a very warm welcome to Workshop. It's great to have you join the community. It sounds like you have plenty of experience to share. I'm looking forward to reading about your projects and plans. Please feel free to post whenever you need a hand or have something to share.
Hi
There are a few ways to remove glue from walls. There is product called Triceleam which can be used also goof off and even acetone will remove glue from walls. You could also try steaming the glue off especially if it was old wall paper. Just becareful not to remove the paper coating from the chiprock as you will then need to use a filler to get your smooth finish. Wash your wash again before painting to ensure that you have a smooth finish. Good luck
Use a product called "ZOFF". It's brilliant !!
My first go to is Tea Tree oil.
Works well when removing sticker/label adhesive from jars, walls vinyl and most plastics.
Happy painting
John
Thanks for joining in the discussion and sharing your experience @JohnM1. Great to see you make your first post. We are looking forward to seeing more.
Welcome,
Eucalyptus oil will also remove gums and glues..Great for removing that gum from stick-on labels that detergents won't remove..
From my experience I would suggest that regardless of whichever product you use to remove the sticky residue, you also wash the walls down well with a mixture of sugar soap in warm water. Otherwise the residue of some of these miracle products may leave their own residue which can show through your fresh coat of paint. I speak from experience.
