Sideboard furniture flip
EleventhCoastal
Making a Splash
Someone else’s Trash became our Treasure with a little bit of love
Materials
Ryobi Sander
120 grit sand paper
 Paint Brushes
Primer Paint
Dulux Wash n Wear Paint
Feast Watson Clear Varnish
Tools
Ryobi Sander
Steps
Step 1
I removed all of the old hardware and then I carefully removed the broken glass from the front door, I then removed the intact piece of glass for the other door
Step 2
I then sanded everything back to raw timber, I used my Ryobi sander and in some parts I hand sanded
Step 3
I wiped over all of the surfaces to remove and sawdust left from sanding
Step 4
In the inside of the cabinet and draws i scuff sanded these prior to painting them with Porters Paints Primer and Paint
Step 5
Once the Primer had dried I then painted all of the sections in Dulux Lime Sherbert
Step 6
Once this was dry I then went over the outside of the unit and the draws in Feast Watson - Clear Varnish in a Satin Finish
Step 7
As the old hardware was quite date I removed all the decorative pieces from the raised handle and sprayed it gold along with one of the button screws
Step 8
I added some door handles that I picked up from Kmart and reassembled the hardware on each of the doors and draws to complete the restoration of this piece.
Kirsty P
Re: Side Board Furniture Flip
Hello @EleventhCoastal
Thank you so much for sharing your upcycled treasure! I love the bright colour you've put on the inside of the cabinet. Those drawer handles look really cool. Are they the original ones that came with the cabinet? What cover will you be putting in place of the broken glass or do you plan to just leave them open?
Again, thank you for sharing such a fantastic project.
Hi Eric,
Thanks so much for your awesome feedback, so I’ve taken the silver part and the gold flat head screw and transformed them with a spray of Gold paint and reinstalled up the opposite way
Before:
After:
This is what the original piece looked like prior to my restoration.
I think I want to put ribbed glass in the doors to keep them light and bright but for now they will remain open.
Thanks again for your kind words
Kirst
Kirsty P
