I’m after some fibre cement sheeting, between 6-9mm thickness. I only have a hatchback car to bring it home but, so want to know what smallest size you can buy is and if they have any damaged stock they sell for cheaper as only need 2 pieces both around 490mm x 560mm each?
Hi @purefunk,
The smallest sheet would be the James Hardie 1800 x 1200 x 6mm 2.16m² Villaboard Lining. It can be cut down with a score and snap knife. The team in-store might also be able to assist you with the cutting. If there are any damaged pieces, they'll be able to let you know. We also offer free trailer hire or a delivery service if you have an issue transporting the sheet.
