I am wanting to install underfloor insulation (ie Earthwool batts) between the bearers under my house.
The measurement between the bearers is 420mm but I am wondering if I could use the 470mm wide batts and squeeze them into the smaller area? The wider batts are more convenient to install as they can be stapled into position by tabs on the sides of the batts whereas the narrower batts need straping.
Thank you
