I wanted a laptop riser for work; however, the ones they can provide was not something I like aesthetically. I therefore made one from a bit of plywood, Okume panel (top), pine, a bit of Jarrah, screws, glue and drawer runners.
I wanted a rail and stile style look to the project.
There is a continuous grain pattern over the inset drawer faces. I made the drawer pulls out of a bit of unnecessary Jarrah for a bit of class and to add a nice contrast to the pine drawer faces. All the sharp edges received a small 45° bevel before I applied several coats of polyurethane finish, sanding up to 240 grit between each coat for a nice smooth to the touch finish.
I made a hidden compartment underneath one of the drawers by raising the drawer box. This is for hiding unsightly messy cables.
The drawers can move freely over the keyboard without interference and offer loads of storage for paperwork, snacks and coffee cups.
The entire project is held together by using either pocket hole screws or a bit of glue.
There is also space next to the laptop area for an extra screen; however, I will be putting a pot plant there and building a separate box for my second screen.
I am also not worried about wood movement as this project will be kept in a climate controlled office.
