Hi all what is the most handy tool I should invest in to mitre skirting boards and door frames? Looking to do our whole 70s place. Thanks and Merry Christmas all
Hi @swk
Try the following a mitre box will guide your saw cut into the timber and give good results. Do buy a good panel saw to work with this Mitre box,
These will start you well into that DIY project
Merry Xmas
Personally given you said you would be doing the whole house I would buy an electric mitre saw. Cheap ones that will do skirting will start at about 110 at Bunnings . Once you have the angle set it will save you hours of work and be easier. Ask about the best blade for skirting you may want to swap for a neater cut. If you intend to start renovating big time it may be worth considering a sliding mitre saw (more expensive but a lot more useable) JDE
Welcome to the Bunnings Workshop community @swk. It's great to have you join us, and many thanks for your question about replacing skirting boards.For several cuts, @Jewelleryrescue has offered a budget-friendly solution, but for a whole house, I'd be going with @JDE's advice of a compound mitre saw. I've used the Ozito 1600W 210mm 8¼" Corded Compound Mitre Saw extensively, and it's performed very well. As @JDE has mentioned, though, for larger work, you might like to consider the sliding option with a larger blade: Ozito 2100W 254mm 10" Corded Double Bevel Sliding Mitre Saw.Please let me know if you have any questions.Mitchell
