How to insulate an existing patio structure?
robert1981
I have an existing gable patio structure which we would like to modernise by insulating the structure and infilling the ends. We would also like to add 2 fans and some heaters to the top so we can utilise the space all year round and enjoy the weather in Western Australia.
The dimensions are approximately 3930mm by 8780mm.2024-02-15 11.23.16.jpg2024-02-15 11.23.30.jpg2024-02-15 11.23.47.jpg2024-02-15 11.24.08.jpg2024-02-26 12.47.50.jpg
Where would I start tackling such a project?
Re: Insulating an existing patio structure
Welcome to the Bunnings Workshop community @robert1981. It's brilliant to have you join us, and many thanks for your question about insulating a patio.
Did you want to keep the peaked roof or bring it down to a flat ceiling?
I'd recommend you take a look at this discussion: How to insulate a metal roof by @bowmatty. Although their reason for insulating was to prevent condensation, their method is also applicable to prevent heat transfer. Installing Foilboard is a fast and effective way to easily insulate a roof and will make a significant difference to your patio area. Alternatively, you could install new beams across the span and use traditional Earthwool insulation and clad over it with plasterboard.
You'll also find a ton of previous discussions on this topic that you might like to browse through.
A note to our New Zealand readers: Foil insulation products are prohibited from use.
