Hi
I am going to attempt to install a VJ panel on a ceiling (attached to the stud) and I have a couple of questions.
I have read the instructions on the Easycraft website and it says to take off 10mm off the length of the board but at the same time it seems to indicate that there is a 10mm cap all around the ceiling (all 4 sides). I just wanted to confirm that it is correct that I would take 20mm off in total off each side (so 10mm gap for each side)?
Where I am installing it has had some water damage in the past. Would the standard VJ suffice or should I get the one for wet areas?
I also wondering if I took my measurements with me is Bunnings able to cut it to size (take off from both the length and width)? If not what tool/s would I be looking at it be able to cut it to size - I am assuming a hand saw would be too painful?
Thank you!
