Hi Everyone
i am planning to build 6meter long and 3.5m wide deck.
i am based in Auckland and i was wondering if anyone would like to share idea about design and if bunnings store provide any help to get the timber and advise?
cheers
Hi @makhan006,
I think you are best advised to start here - How to plan out your deck. You'll notice it is part of a comprehensive seven-part series on How to build a deck.
We also have how-to guides here on the Workshop community, as well as plenty of inspiration such as our Top 10 most popular deck projects and Inspiring low-level deck builds.
What is the structure in the foreground of your photo? It looks like you already have a deck of some sort?
Once you have a clear plan on what you'd like to achieve, I'm sure our helpful community will be more than happy to assist.
Hello @makhan006
Thank you for sharing your question about how to build a 6 x 3.5-meter deck. Looking at your photo, it looks like there is already a deck present. Will you be connecting to this deck at the same level? How big is that deck in the foreground? I suggest having a quick look at this guide - How to build a low-level deck by @Adam_W. This will give you an idea of what you need to take into consideration when making your decking plans.
A commonly used timber framing size is 90 x 45mm L/M Outdoor Framing MGP10 H3 Treated Pine. You can use bigger timber framing sizes, but I don't recommend going any smaller than that. If you don't plan on digging into the ground to plant posts, I suggest looking at Builders Edge Pedestal Feet. These are designed to go on top of pavers and are fully adjustable so that you can get a level frame.
Here are some fantastic decking projects our Workshop members have shared:
These decking projects should give you an idea of how to plan your decking frame and in which direction your decking panels will be running in.
