This large built-in unit made of five Montgomery bookcases brings a bright new look and loads of display space to a dated rumpus room.
The project
We saw a built-in bookcase like this on Pinterest and decided to give it a go!
Our downstairs rumpus room had been in need of some TLC for a very long time. The bookcases on the left had come from another house and were uneven, covered in nails and not overly functional. The room was a bit dingy (and probably still will be until we replace the carpet and lights) so I painted the wood-panelled wall and started on the bookcase.
We used five Montgomery 80cm x 28cm x 202 cm six-tier bookcases, which we assembled and bolted together. Once they were bolted to the wall we got to work framing them in.
We popped in some supports and then attached the timber to that. Our house is not square so we literally moved a wall to make it flush! We finished it off with a quick sand and some paint.
I'm pretty stoked with how it has turned out. I am trying to decide whether we fill in the holes for the shelves and paint the inside of the bookcase or leave the holes there so we can move shelves around.
More project inspiration for your home
Bunnings Workshop member Benskimo custom-made this brilliant mid-century modern shelving unit to fit a tricky space.
Workshop member Wooshka made these clever floating Acacia shelves on a Jarrah beam.
There are also plenty of great ideas in our Top 10 most popular indoor furniture projects and Top 10 most popular storage projects.
Let us know if you need a hand with your project – we're here to help.
