Hello BW,
This is another project on Square Set opening with either Timber or metal material.
Some of the sample Square Set Opening is provider below, where Timber is used for the design on one photo and metal on another.
I would like to have any one of the above design in my living room in the space as shown here under.
The questions, I had are (for Timber material)
1. What timber material is fit for the purpose.
2. For painting in in light brown to match with the shelfing, should I remove the shelf door and compare with the paint cards for exact match.
3. How to fix the timber frame, exactly in the square set opening. On above image, I could not find any screws for fixing it in square set opening. Is there a quick fix mechanism available for locking the frame within the opening.
(if it is for steel),
1. Can bunnings assist on laser cut for above design.
2. Does Bunnings sell any design in Steel frame that I can paint and fix in to the opening.
3. How to fix the metal frame in to the square set opening. Is there a quick fix mechanism available for locking the frame within the opening.
Hoping to work on this project with your recommendation and assistance.
Happy Maintaining your space.
Thanks
MM
