is your product I/n 6660430 and 31 suitable for a 9mm thick VJ panel?
Hello @geoff3,
Welcome to the Bunnings Workshop community. It's fantastic to have you join us, and thank you for sharing your question about the Wall Art corner joiner.
The Wall Art panels are only 3mm thick and the corner joiners are designed to fit Wall Art panels only. However, if you are keen to use a PVC finish to cover the joins, I suggest having a look at the Brutus 19 x 19 x 2.5mm 2.4m PVC Building Moulding. This can be used for both internal and external corners. It is possible to staple them into place, but it would be better to simply glue them on.
Here is a link for the Easycraft finishing options: Easycraft finish options
Here are some amazing EasyVJ projects our Workshop members have shared:
