Steps
Step 1
Cut timber lengths.
Measure and mark timber according to the cut list below.
Clamp the timber securely to the saw horse and use a circular saw to cut the lengths accordingly.
Mark all the cut pieces with a black felt pen indicating their size. These will be the pieces used to form the cabinet's frame.
Use a Kreg jig to pre-drill mounting holes on both ends of all the cut timber pieces.
Cut list:
- Three pieces measuring 70 x 35 x 1640mm
- Two pieces measuring 70 x 35 x 1570mm
- Two pieces measuring 70 x 35 x 1535mm
- One piece measuring 70 x 35 x 1710mm
- Eight pieces measuring 70 x 35 x 360mm
- Two pieces measuring 70 x 35 x 425mm
- Eight pieces measuring 70 x 35 x 527mm
- Four pieces measuring 70 x 35 x 516mm
- Two pieces measuring 70 x 35 x 500mm.
Step 2
Construct the cabinet sides.
Take one piece of the 1570mm cut timber, two 360mm pieces and one 500mm piece. Form a small letter “d” with the 360mm pieces positioned horizontally inside and the 500mm piece on the outside. Clamp all pieces together on the saw horse to prevent movement. Use 64mm Kreg screws to secure them together.
Repeat the above steps to construct a second “d”.
Now clamp one “d” frame to the saw horse. Make sure it is standing up. Take two of the 1640mm cut timber pieces from Step 1 and clamp them perpendicular to the bottom of the “d” frame. Screw them to the frame.
Clamp the other “d” frame and screw the 1640mm pieces in from the other side. Once the two bottom pieces are secure, lie the entire frame downwards and secure to saw horse. Screw the next 1640mm piece to the top of the 500mm piece as seen in the photo.
Step 3
Assemble the rear frame.
Place two pieces of the 1535mm cut timber on a flat surface. Space them apart using two 527mm timber pieces on the sides and a central 516mm piece in between. Screw these timbers together.
Stand frame up and position the 1710mm length on top of the frame. Screw the 1710mm length to the ends of the 1570mm lengths (shaded yellow in the photo below).
Step 4
Construct the shelf frames.
Take two of the 360mm cut timber pieces and screw them to the top and bottom parts of the lower frame and in line with the 1535mm vertical length.
Now screw the 430mm pieces in front of the bottom frame (refer to photo below shaded in yellow).
Repeat the process to construct the next segment of the cabinet’s bottom (refer to photo below shaded in green).
Step 5
Install TV mounting studs.
Attach six 527mm mounting studs between the outside vertical uprights on the cabinet’s rear frame. Then attach three 516mm mounting studs between the central uprights (refer to photo below shaded in yellow).
Now secure the centre uprights to the 1710mm timber length on top (shaded in orange in photo below).
Step 6
Attach the rear and top side panelling.
Place the V Grooved panel in front of the cabinet's vertical uprights and secure with clamps.
Mark the top and side of the panel in line with the frame. Cut the panel accordingly using a circular saw.
The off-cut pieces from the panel will be used to cover the vertical sides of the frame. Position one of these pieces on the side of one of the cabinet's exterior vertical uprights to form a side panel. Drill a pilot hole on top of this side panel and secure it to the exterior vertical upright with a 25mm timber screw. Repeat for the other side.
These side panels will need to be trimmed flush with the frame. Line up the front cover panel with the side cover panel and secure with clamps. Once all the panels are lined up and square you can secure them with 25mm timber screws.
Step 7
Attach the bottom side panelling.
Measure the width and the height of the bottom side frame and cut the V Grooved panel to suit. Use a circular saw for cutting.
Position the cut panel on the frame’s side and screw in place. Repeat process for the other side.
Step 8
Install shelf liners.
You’ll need three MDF panel sections to line the bottom of the shelves and six panel sections to line the sides of the shelves.
Measure the length and width of the base sections and cut the MDF panels according to these dimensions. Next, measure the width and height of the side sections and cut the MDF panels to suit.
Now measure the width of your cabinet frame and cut two lengths of 40 x 18mm Pine moulding to suit. Screw the bottom trim to the frame so that it is level to the MDF panel inside. Repeat the process for the top of the cabinet.
Once both trims are in place, screw the MDF panels into the cabinet frame.
To cover the frame’s exposed front, measure and cut four covering strips from the MDF panels to suit. Screw these into position.
Step 9
Install shelves.
Install four shelf support brackets in each of the frame’s lower divisions. Space the shelf supports 400mm from each other on the side panel. You’ll need three shelves, one for each of the divisions.
Measure the distance across each division and cut the 800 x 450 x 18mm panel to suit.
Step 10
Construct the cabinet's tabletop and paint.
Position the 1800 x 600 x 18mm timber panel on top of the cabinet’s bottom frame. This will form the cabinet’s tabletop. Allow a 20mm overhang on both sides of the frame and a 20mm overhang on the front.
Trim panel to size. This will leave you with an off-cut piece. Screw this off-cut to the top of the rear panel.
Now fix a trim piece cut to the width of the rear panel directly under the off-cut to balance the look of the cabinet.
Add final touches to your cabinet by painting it and adding your preferred finishes.
Once dry, you can attach a standard bracket for hanging your TV. The Bunnings team has a step-by-step guide How to install a TV wall mount that you can follow. Make sure you attach the bracket to the studs from Step 5.
