Office makeover with VJ panels, timber shelves, desk and new paint.
The project
I updated my home office that seconds as my library. I used VJ Panelling, Project Panels, Shelving Brackets, paint and hardware all from Bunnings and I'm very happy with the result.
We started with three 2400 x 1200mm VJ panels, which were then cut down to size and fixed to the wall directly in the studs behind that had been marked out earlier.
Once hung, we were able to tape up the wall, and start painting. Tip: Make sure you have some light sandpaper to run between the grooves of the VJ as it is a bit rough. This will give you a nicer finish when painting. We used Dulux Dinosaur.
Both the desktop and shelves were made from the Beech Laminated Panel from Bunnings. One was full size and the other one was cut down to make the shelves. Again, the brackets were fixed directly to the studs.
We're very happy with the outcome and are looking at eventually hanging more shelves on the other side of the room to watch the ones in this picture for more storage space.
